Low idle sputter on my 97 Civic ex
Old Jul 4, 2011 | 06:26 PM
SpiderSlam's Avatar
Default Low idle sputter on my 97 Civic ex
Hey all, I currently have a 97 Civic ex and I have a problem.. When I first bought the car, sometimes when im idling the cars rps would drop below 1k and the car would shake and sputter like it was about to stall then the rpms would shoot back up and everything was fine. Now recently it did it even lower and a bigger stutter and I noticed even my interior lights dims greatly, what could this be? Just so everyone knows, the car has NEVER stalled on me from this. But it seems its getting worse and I want to sell the car.
1997 Honda Civic ex
Automatic
Sedan
Stock
Old Jul 4, 2011 | 06:36 PM
agentorange11's Avatar
Default Re: Low idle sputter on my 97 Civic ex
Mine did the same thing could be your idle air cantrol valve ( iac ) or your throttle position sensor ( tps ) or a vacuum leak. I would look for leaks first and then change out or clean your sensors. just my thoughts. Mine was the tps.
Old Jul 4, 2011 | 10:00 PM
tinctorus's Avatar
Check to make sure that the spark plug seals on the valve cover care NOT letting oil get in contact with the spark plugs, I had the problem on one of mine and it would idle hella rough and feel like it watned to stall.
All I did was pull the valve cover and replace the v/c gasket as well as the spark plug gaskets and the problemw went away
Old Jul 5, 2011 | 07:38 AM
frankenghia's Avatar
iacv.
Old Jul 5, 2011 | 07:42 AM
virgineg6's Avatar
Do you have a CEL? when was the last time the car had a full tune up?
borrego805
Feb 14, 2015 04:28 PM
Elementcct
Aug 23, 2012 07:37 AM
jamesd86
Sep 9, 2011 04:32 AM
defaced8
Apr 9, 2007 04:57 PM
1hotintegra
Oct 2, 2002 04:55 PM
