97 Civic EX; bad idle/weird idle
Old 09-08-2011, 07:35 PM
jamesd86's Avatar
Default 97 Civic EX; bad idle/weird idle
Hello all, just recently purchased a 97 Civic EX, 1.6 vtec, automatic transmission with almost 200k on it. No major problems at the moment except for a really rough idle, especially when the a/c is turned on. Well, really whenever there's a load put on it...like, touch the brakes, turn the lights on, turn the defrost on...anything besides just running at idle will knock the rpms down alot. Usually will go from 800(+-50) to bouncing and almost stalling. My thoughts are the alternator needs replaced, just wondering about a second opinion.
For the weird idle...When i'm in park or neutral and I tap the brakes, the idle will drop quickly..but if I pump the brakes a few times the idle will actually shoot up and hit around 1100 or so. Thoughts?
And last question(for now -.-; )...when i'm on the highway doing about 60 or so, should I be taching about 2500 rpm?? I'm used to my Blazer that would be about 1400 at that speed.
Thanks for any help.
EDIT: forgot to say this thing is like bone stock...aftermarket cd player and remote start. the rest is stock.
Old 09-08-2011, 08:13 PM
Former User's Avatar
Default Re: 97 Civic EX; bad idle/weird idle
Pull out your handy-dandy multimeter and set it to measure DC voltage. Compare the voltage across the two battery posts with the engine idling under no load versus high load (with the high beams and rear window defogger on).
Old 09-08-2011, 08:18 PM
joeshmo's Avatar
A good alt will usually put out more than 13 but less than 15v to the battery. Mine does 13.7 when the engine is running well.
Old 09-08-2011, 09:34 PM
jamesd86's Avatar
So just hook up to the positive and negative and monitor the level as I put the engine under load?Have to pick up a multimeter(probably a good idea if I'm going to keep the civic as a lot of the trouble shooting calls for using one no?) in the morning. Will post result of test.
Old 09-08-2011, 09:49 PM
joeshmo's Avatar
Yes, multimeters are great tools to have around. I have 4. Measure the voltage between the two terminals of the battery.
Old 09-09-2011, 04:32 AM
jamesd86's Avatar
Well, alternator checks out good
I'm not sure what's causing it to bog down now
I can deal with just turning the a/c on/off at lights or when i get moving...my wife..not so much..in park the compressor kicks on and the engine gives one hell of a shake, maybe low or overfilled?(the guy i bought it off of said he had filled it beginning of summer maybe?)
battery w/o load 14.3
battery w/ load 14.0
i assume that's good.
VTECwalka
11-04-2012 06:58 PM
Tyme2Breathe
05-05-2009 02:28 PM
SaLvAcIvIc97
11-15-2007 08:23 AM
thisboyjulio
09-10-2006 09:50 PM
Quick Reply: 97 Civic EX; bad idle/weird idle
