dead 95 coupe/LS swap - fuel pump won't run
hello got a quick question for anyone. i got a 95 coupe with a 92 ls in it that is decked shaved crower cams built head. ran great then the other day fuel pump stopped working. changed fuel pump fuel pump relay and checked all wires. seems fine. fuel pump will not kick on when you turn the key all the way on. will turn on if i disconnect the relay and jump prong 5 and 7 on the plug. but car will not start. please offer some advice or assistance.
yes the fuel pump does when i connect them. and yes it was brand new. i have ordered another one . waiting for thr relaay now. im trying an integra one
I had that problem on a 93 del sol si. I even replaced the ignition switch. Turns out it was the ECU. Try another ECU to see if the fuel pump will prime and the car will start. My old ECU appeared to get wet. The ECU cover was oxidized from moisture. I think any other P28 ECU (s/b manual or auto correct application ) will prime the fuel pump
potatostix
10
Jun 17, 2023 10:27 PM
Whiteonblackej
82
Mar 19, 2015 12:55 PM
ssdjoey1904
Aug 6, 2014 04:48 AM
JimmyM86
15
Oct 18, 2007 08:44 PM
