1991 accord stalling, dying issues
Old Jul 4, 2011 | 01:17 PM
jacep25's Avatar
Icon2 1991 accord stalling, dying issues
i have a 1991 accord ex that i bought and i need help. i have done alot of work to it by reading post and stuff...this is what i have done.
new fuel pump
reman distributor x2
new rotor and cap
new wires and plugs
head job
new main fuel relay
new pvc
cleaned out the idle contol valve
new timing belt
new water pump
new o2 sensor
new fuel filter...new thermstat
think that is it...lol
something to note..got car this way before i got work done....when i plug in the sensor for the temp guage it goes straight to hot...so i have it not connected. they put a aftermarket temp guage on becuase of this and it is put where the a sensor goes on the water outlet housing in front of engine(top radiator hose).
this is what my car does....starts right up and drives perfect plenty of power..i mean no issues..after it warms up my tach will bounce around..sometimes to 0 which then i lose power but car is still on. sometimes it will kick back to normal or somtimes it will die....when it dies it will start right back up with it dying right away..but aster i couple of tries it will stay running..but still acts up immediatlly. NO CEL
any help would be appreciated? i am lost lol
Old Jul 4, 2011 | 07:50 PM
lzrd17's Avatar
Default Re: 1991 accord stalling, dying issues
check the voltage from your throttle position sensor. should be .50 volts closed throttle and 5.00 volts with the throttle wide open. do this test with the key in the run position withe engine off. jumping the blue 2 pin connector under the glovebox or passenger kick panel should give you a code 7 for low or high voltage from the TPS. hope this helps
Old Jul 4, 2011 | 08:19 PM
jacep25's Avatar
k i did that and came up with 41 ...o2 sensor changed it and now the CEL is off.
i will check the tps voltage tommorow...thanks.
Old Aug 18, 2011 | 03:52 PM
jacep25's Avatar
Default Re: 1991 accord stalling, dying issues(PROBLEM SOLVED)
AFTER SOME MORE RESEARCH...I CHECKED MY ECU GROUND AT THE THERMSTAT HOUSING. IT WAS REALLY LOOSE(LOL HAD THE COOLING SYSTEM DONE BY A MECHANIC WHO CHANGED THE THERMASTAT AND HE DIDNT TIGHTEN DOWN BOLT). I TIGHTENED THE BOLT DOWN AND PRESTO MY HONDA WORKS PERFECT.
SO DONT FORGET TO CHECK THE ECU GROUND AT THERMSTAT.
turbo_civicd16
Sep 21, 2016 12:07 PM
Ragusano
Classic Hondas
Sep 4, 2013 09:06 PM
Tizzakowack
Mar 5, 2009 05:15 PM
hondastrtracr
May 1, 2006 09:12 PM
