Engine build question
Old Jul 4, 2011 | 10:08 AM
hybridmiklo's Avatar
Default Engine build question
Whats up guys, i have a somewhat noob question. Doing my first engine build and just finished taking out the rods. I want to know how do i measure the bearing clearance so i know what bearings to get? (standard, oversized). Am i supposed to plastigage it with the stock used bearings?
Old Jul 4, 2011 | 11:10 AM
p10hlm's Avatar
Default Re: Engine build question
http://www.youtube.com/watch?v=mpy_By5aIxM
http://www.youtube.com/watch?v=MtTXA...eature=related
http://www.youtube.com/watch?v=JE7U5...feature=fvwrel
Old Jul 4, 2011 | 06:53 PM
Thanks a bunch. This is extremely helpful.!!!!
Old Jul 7, 2011 | 02:23 PM
that last post was awesome. I really appreciated the help. My last question is how are there "sets" of bearings from acl when supposedly the bearings are different from journal to journal?
Old Jul 7, 2011 | 08:50 PM
W!d3b0dYr3X's Avatar
The bearings from acl are "one size fits all". If you check yyour clearances and they vary too much I would recommend using the color chart and staying with oem bearings. if they vary a lot and you wish to go with acl I would get the crank micro polished have the mains align bored larger and run with ovrsz acl
Old Jul 7, 2011 | 09:07 PM
civickiller's Avatar
if it were me, id just run the correct honda bearings
Old Jul 7, 2011 | 11:46 PM
cool, i get it. I would love to just run oem bearings but they run for around $12 a bearing. That turns out to be a crap load.
Old Jul 7, 2011 | 11:56 PM
cibao2ner's Avatar
if u look at the 5 letter stamped on the block and then at the letter on the crank u can spec out wat color bearings your engine will need therefore you will know if u can use the acl bearings which are closer to the factory green bearings...
Page3905
Jun 4, 2012 04:51 PM
TurboKneeGrow
Mar 18, 2008 07:22 PM
TurboKneeGrow
Mar 18, 2008 02:58 PM
2000Accord5sp
Jun 12, 2002 11:23 AM
civbeater90
Jan 12, 2002 11:56 PM
