2007 Si coupe, no start
Searched. On cold and hot restarts vehicle will not intermittently not start. Replaced battery first about 3 months ago because it did not pass, then it was brought to the attention at the dealer that the car does not turn over sometimes. Of course dealer could not replicate, understandable. Decision to replace the starter. Still having the issue. Any of you 2006 or 2007 Si drivers having this issue?
I would check the battery cables, work your way back from the battery, follow the cables and make sure every connection is tight and clean.
My first guess would be the ground cable making a intermittent connection.
2DoorBandit
15
Jul 20, 2011 03:54 PM
JDM EJ2
Jul 6, 2008 04:39 PM
