D16Y8 missing cylinder
usally still runs semi normal but shakes more then normal and has no power when accelerating. you can check it by pulling the spark plug wires one by one while the car is running.when u pull the plug wire the motor should die down some but if the car does not die down and idle stays the same then u have a dead cylinder.Then you need to diagnose from there. i recommend using gloves when doing this as getting shocked by a plug wire is not fun and stings a lil more then an electric fence. you could also put a screw driver in the plug wire and have someone hold it near a grounded bolt and have them watch for the spark to arch from the screwdriver to the bolt while you crank over the motor. repeat to all 4 plug wires. hope that helps
TOO MUCH TORQUE
Jun 17, 2012 06:45 PM
ss85510
11
Oct 2, 2010 09:42 AM
JSTOCK
Apr 25, 2002 03:14 PM
