valve tick and no pwer
Got a 01 s2k that I had just replaced head with one I had valve job done. It ticks even after I adjusted valves 3 times. it also don't have the power it should and struggles at top end. Any thoughts on what this might be?
ok, so got the valve ticking noise fixed, but still need to know whats causing the lack of power at top end....any suggestions?
yea, timing is dead on.....it just struggles at top end....also when the car is at normal temp., it cranks over like it has a weak battery.....starter and battery has been replaced. battery terminals also been replaced. all ground connections are good.....anybody had this problem before?
wheww. timing guys? k, first and foremost start with a 25 minute comp test.. then a leak down test.. that will answer a lot of questions,
as far as the valve adjustment if you've done it 3 times, ehh, i would check the comp/leakdown, then bring it to a good shop
euG3dc2r
Feb 23, 2005 03:45 AM
