harbor freight 171 mig welder on sale this month
a lot of people have had success with this mig. if you looking for a budget mig, for $200 you cant go wrong. for a few extra buck get the replacement plan
the coupon is for itc members. it will work without the car. if they ask you for the card lie and say you just signed up the day before and its not active/you dont have it on you.
http://insidetrackclub.harborfreight...der-93793.html
Description of Chicago Electric Welding Systems 93793
This is one versatile welder, complete with six dial-selected output settings. Comes set up for Flux Core Arc Welding (FCAW) for hassle-free operation at the start. Add gas components for full MIG welding with shielding gas later on.
* Manual wire feed speed control, handles spools up to 10 lbs.
* Dual groove knurled drive roller
* Thermal overload protection with indicator light
* 7 ft. welding cable with gun
* 7 ft. ground cable with clamp
* Convenient pull handle
* Smooth rolling wheels and swivel casters for easy transport
* Gas cylinder platform with chain (cylinder not included)
* Overweight Item subject to 14.95 additional Freight Charge.
Input: 240 volts, 30 amps, single phase, 60 Hz
Rated output current: 35 to 140 amps
Rated output voltage: 16 volts @ 140 amps
Max open circuit voltage: 32 volts
Duty cycle: 40% @ 140 amps
Wire capacity: 0.024" to 0.030"& 0.035"
Wire feed rate: 37 to 812 inches per minute
Weldable materials: Mild steel, low alloy steel, and stainless steel (not suitable for aluminum)
Material thickness: MIG: 22 gauge (1/4" thick), FCAW: 22 gauge (3/8" thick)
Includes: Spool of 0.030" flux-cored wire, two spare contact tips (0.030"/0.040"), handheld face shield, chipping hammer with wire brush, multi-purpose wrench
Shipping Weight: 99.18 lbs.
print the coupon out black and white and cut out the inside track part on the top, they prob wont even notice..............
ok, i finally made room in my budget to get this tomorrow. ill go after work. ill report with pictures.......
yup, dident even ask for the itc card. its worth a shot, and if they do ask for it say you just signed up online yesterday and the account isent active yet. either way the coupon orks without the card.
machine works good, i dont have any pictures. i havent used mine yet, but we did use my friends the we got at the same time. did some exhaust, floor pans in a 75 impala and other misc things. no complaints.
no. it actually feed pretty well. i have used 3 or 4 of the HF welders and havent had any problems.
are u sure the correct size wire was being used with the right tip nozzels? they do come in different sizes.
yeah, it was just a really cheap welder. I have been welding for about 3 years I just had to sell my Hobart welder about 5 months ago. I am realdy to get back into it but I don't have $500-$600 for another Hobart.
Want2race
Welding / Fabrication
Dec 23, 2004 08:34 PM
