help b18c/b16 leaking a little oil were block meets tranny casing
Old Jun 30, 2011 | 02:58 PM
96ekjim's Avatar
Default help b18c/b16 leaking a little oil were block meets tranny casing
just noticed it today and title says it please help!
Old Jun 30, 2011 | 03:08 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: help b18c/b16 leaking a little oil were block meets tranny casing
A pic or two would help a lot.
How dark in color is the leaking oil?
The next sealed seam over holds the trans fluid in, not the bell housing>block seam.
Old Jun 30, 2011 | 03:17 PM
96ekjim's Avatar
not the belt housing side the other side a little above were the b18c stamp is on the block ill try to get picks up soon
Old Jun 30, 2011 | 03:19 PM
96ekjim's Avatar
also the color at first was a darker color then i ran the car for a while and it was then a lighter color
Old Jun 30, 2011 | 03:22 PM
BryanM.'s Avatar
Resident Gearhead
Probably a leaky cam plug, distributor seal or VTEC solenoid seal or even the valve cover gasket. All very common.
Old Jun 30, 2011 | 03:24 PM
96ekjim's Avatar
cool thanks ill try to get a picture up very soon so you can get a look at whats going on.
Old Jun 30, 2011 | 11:42 PM
akelly17's Avatar
i had a ls vtec that did the same thing. it is coming from in between the head and block ( headgasket). car didnt overheat, or lose coolant but it dripped oil everywhere.. not a big deal unless its a pretty big leak. mine was so bad i chose to redo the head gasket and i found that the previous owner didnt use dowel pins, had the wrong head bolts(ls), and used the wrong head gasket. if you arent sure how legit your swap is, it wouldnt be a bad idea to throw a new mls head gasket on it. it probably saved my motor in the long run and it only costs 50 bucks as long as your head and block is straight. also gives you a good chance to inspect pistons, valves, sleeves, etc. and it shouldnt take more than 3-5 hours.
Old Jul 1, 2011 | 06:25 PM
96ekjim's Avatar
yea its defenentally the head gasket and barely drips oil so im fOR sure going to put a new on in, thanks for the help!
Old Jul 1, 2011 | 07:23 PM
akelly17's Avatar
Yeah its definitely worth it. And relatively cheap and a great way to go through your motor!
saemoonyang
12
Jun 7, 2010 02:01 PM
scspeed
Mar 28, 2010 06:50 AM
mouab18c1
Jan 26, 2010 12:43 PM
lilskud13
11
Dec 18, 2007 08:15 PM
ALL MOTOR DA
11
May 1, 2006 02:48 PM
