Coil Check Help (I unplugged spark wires while running)
Old Jun 30, 2011 | 02:15 PM
EG6Hatch95's Avatar
Default Coil Check Help (I unplugged spark wires while running)
So like a dummy I unplugged spark plug wires to see what was going on with my idle but when i did my car died and now it wont start
did a search and found out this is a common way to blow your ignition coil
I tested mine and got between 0.9 and 1.1 ohms resistance depending on how i positioned the prongs on the primary test. should be 0.6-0.8 so that was no good I assumed.
I then went to buy a new one the brand was BWD I tested the new one and got the exact same resistance. So I returned the coil to find out more which is why I am on here
should I still replace the coil? could the brand BWD have a differnt spec that just so happens to be what im getting on the one currently in my car?
what else could have I done to my car? I checked spark and Its definitly not there
fuses are all good as well
Old Jun 30, 2011 | 02:27 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Coil Check Help (I unplugged spark wires while running)
http://techauto.awardspace.com/ignition.html
check your ignitor also
JuniorDDavis
41
Mar 5, 2012 12:43 PM
civickiller
Feb 21, 2007 03:11 PM
CivicSiRracer69
Nov 27, 2004 12:30 PM
Yambor
Jul 30, 2004 06:55 AM
crxzc
Jun 9, 2002 06:50 PM
