what drill bits for stainless?
drill i small pilot hole first and use oil while you're drilling through. cobalt will go through without issue. are you starting with a 1/2" bit or something?
u have to go slow with lots of pressure and lube for regular drill bits or they will burn up so you have to keep them cool
u need good drill bits like titanium tip bits, lubrication is a plus i like a mix 20-80 water oil, water cools it while oil lubes it
Or even better you can get some carbide bits (problem solved) i drill stainless gutters all day at my electric company
lol we only use gutters on commercial buildings where it is either always in humid conditions, around chemically treated water, or boiler rooms, any where there is lasty stuff we wanna keep out that can and will eat thru mild steel
also if u got that drill bit kit from lowes then that cobalt is the name brand not qaulity but even so it should drill atleast one hole fast or slow like i said get a titanium tip drill bit set and dont look back there not expensive and you wont be breaking your back waiting for the hole to be drilled
i got to kits , a cheap drill bit kit for regular stuff and titanium tip for difficult stuff i also got the carbides for precision holes that have to be drilled out perfectly with no debur
Buy some Good Cobalt bits. Those cheap bits are junk. I was struggling with cheap cobalt bits then went and bought like 4 drill bits from a good company and wow drills thru it like butter.
Drill a small hole then step it up also at a slow speen to fast and your harden the stainless.. That way your bits last for long time. Also try to use a press if you can.
then titanium bits from Home Depot and most have tips meant to center,start holes and pre drill the pilot hole already on the larger bits
unless i lost, broke, or damage a titanium bit by trying to drill a hole thru metal near a concrete wall i went to deep into them they last a long time had mines for 10 years minus a couple 3/16 bits
you need to know what type of bit your using to know what tech to apply, with most bits made of cheap metal (slow hard and lube)
with steal bits (slow to moderate speed, moderate pressure to hard and lube)
cobalt bits are just harder and can take a little bit more heat so slow to start hole then moderate speed to drill it out
stainless steel bits you have to put pressure and lube your basically drilling with the same material just heat treated to make it harder but it can still burn up and if you see any of the bits glow red then your bit is no good no more, you can use the wd40 to tell when your get to hot so that you can either slow down or stop spray with wd40 to cool it and proceed
titanium is hard can take lots of heat and you can go slow or fast, and if you use lube it will last almost forever
theres other types but they cost$$$
I have seen bits melt on stainless steel and snap because ss doesn't usually (dont know the correct wording) deburr like regular metal like the lil flakes it will some times make long hard flexible, sharp strings of metal that will go around your bit or worst thread into the hole instead of drilling it out that's why you have to use only the proper force or you can force to bit to shatter
