how to remove the front wheel hub on a 92 cx?
Old Jun 29, 2011 | 03:44 PM
efeher's Avatar
Default how to remove the front wheel hub on a 92 cx?
i need to replace the wheel studs and i am pretty sure i have to remove the hub. i have never removed a hub. any tips suggestions or good guides?
thanks
Old Jun 29, 2011 | 04:03 PM
SlickC95's Avatar
Default Re: how to remove the front wheel hub on a 92 cx?
hey man here is a link that i used to show me how to replace my bearings and studs
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-install-wheel-bearings-lower-ball-joints-pic-intensive-1567042/
Old Jul 1, 2011 | 04:46 AM
efeher's Avatar
thanks bro
Old Jul 1, 2011 | 04:50 AM
soon2bdropped's Avatar
if you have access to a slide hammer. you bolt the slide hammer to the hub.. and pull it off just enough to remove the stud and install new one. and than use the axle nut to tighten the hub/bearing together. i've done it and it works.
ewoo
Feb 24, 2009 04:23 PM
96_9c1
Mar 15, 2008 05:34 AM
em1mata
Apr 5, 2007 10:27 AM
jap_tek
Apr 4, 2003 09:01 AM
apexii
Jun 6, 2002 07:56 AM
