Is my ZC basically a D16A6?
Old Jun 28, 2011 | 06:01 PM
crxguy406's Avatar
Default Is my ZC basically a D16A6?
So I need to buy a bunch of parts for the SOHC ZC (non-vtec) I'm swapping into my 90 CRX DX, but I'm tired of getting confused looks from the parts guys. Being I don't know a lot about engines myself, I set out to find what the closest USDM equivalent to my ZC is.
This is from wiki..
"The non-VTEC SOHC ZC is similar to the D16A6 ('91–'96) and D16Y4 ('96–2000) engine, but with more aggressive cam timing"
The only other information I could find was about the v-tec and the DOHC ZC's (which I don't have.) My question is, what was different about the 88 to 90 civic d-engines? I don't know exactly which car my motor was pulled out of... so when they ask which engine I need the parts for, what do I tell them? Here's a picture if that helps.
Old Jun 28, 2011 | 06:45 PM
1990edsedan's Avatar
Default Re: Is my ZC basically a D16A6?
same block, same internals, same head as the d16a6. The only thing different is the cam...
Old Jun 28, 2011 | 07:13 PM
D16SiHatch's Avatar
yep, and even the cam is only very minimally different. other than that they are identical.
Old Jun 28, 2011 | 11:45 PM
garthjenkins's Avatar
word, I have a d16a6 in one ef hatch and a zc in the other basically the same, just different cams
Old Jun 28, 2011 | 11:52 PM
Tyson's Avatar
that whole wiki blows and needs to be deleted.
"ZC" means D series, 1.6L.
doesnt matter if its carburated, dual cam, or VTEC. 1.6L D series is the only common denominator.
YOUR ZC may be from a previously carburated head or MPFI. the cams are each different. the MPFI ZC is closest to the A6. but its not the same. carburated is totally different.
full break down.
http://www.norcalcrx.org/tyson/SOHC_Cam.html
Old Jun 29, 2011 | 05:56 AM
crxguy406's Avatar
Thanks for all the info. So being my ZC is non-vtec, SOHC and MPFI, I'd be safe ordering parts for the D16A6? (For example, a complete gasket kit.)?
Old Jun 29, 2011 | 11:31 AM
Tyson's Avatar
dear god...
YES
Old Jun 29, 2011 | 12:29 PM
finally thanks for the specs I have been arguing for too long about the cam difference between multiP zc and d16a6 now I can show the specs and be like what see son!
patrickstar
Feb 15, 2009 07:38 PM
JaHnAbOi
17
Jul 17, 2006 05:07 PM
Gant
10
Apr 29, 2004 05:26 PM
Superhatch
Sep 14, 2003 11:43 PM
UrMyI3itch
Jun 26, 2003 11:25 PM
