Master cylinder brake line plugs
Old Jun 28, 2011 | 02:08 PM
Boosted_B_Series's Avatar
Default Master cylinder brake line plugs
I've searched and searched, last thing I need for my staging brakes to work.
I need a way to plug one of the holes on my master cylinder.
The thread size is 10mm-1.0
Thank you for your time,
Dk
Old Jun 28, 2011 | 02:45 PM
turbo-2nr's Avatar
Default Re: Master cylinder brake line plugs
call stan at fast-turbo
Local/Int'l: (817) 439-3748
Toll Free: 1-877-988-8726 (98 - T U R B O )
Old Jun 28, 2011 | 05:31 PM
redboost10's Avatar
local hardware store should have a set screw or at least a nice looking bolt to use.
if not, mcmaster has them and/or if you got a lathe should be able to make one with no problems.
Old Jun 28, 2011 | 05:59 PM
Thank you, fast turbo is a good company!
Thank you, I wonder about the flare it needs to seal, or if its needed.
Old Jun 28, 2011 | 07:41 PM
turbo-2nr's Avatar
i would want it lol, brake system is not something to "rig" together think of the guys in the lane next to you at the track if you dont want to do it for you self
Old Jun 28, 2011 | 09:20 PM
I understand, that was my concern.
I found one way to do it, kinda expensive but I ordered em just to have.
10x1.0/3an adapter, with a 3an cap on it.
I use this till I can find a plug that'l work.
Old Jun 29, 2011 | 07:14 AM
HickamHatch's Avatar
Why are you capping it?
Old Jun 29, 2011 | 10:11 PM
Deleting the rear brakes from the normal brake system.
Only thing that operates the rear brakes is the staging brake.
Plan is to come out of the front port of the master cylinder, 3an to a tee, from the tee two equal length 3an lines to each front caliper. Block off the rear master cylinder port.
Staging brake has its own master cylinder. 3an out of it to a tee, then to equal length 3an lines to each of the rear calipers.
Car has skinnies, last thing I want is the *** end passing me on shut down. I've had it happen on normal street tires before in this same car.
Thanks for your time
Dk
Old Jun 29, 2011 | 10:12 PM
Sounds like a good plan
Dk
Old Jun 30, 2011 | 12:36 AM
Thank you, its pretty much done, just need a few more fittings to arrive.
Gotta come up with a solid kit, my brother and girlfriend are going to be on skinnies soon as well.
Old Jun 30, 2011 | 02:19 AM
cibao2ner's Avatar
can the staging brake work with rear brakes? can u have the car brake normal when staging brake isnt used?
Old Jun 30, 2011 | 11:34 AM
MrParks's Avatar
yes, there are 2 kinds of brakes when coming to hand controlled brake.
you can do a hand brake or a staging brake. the stage brake with tee off to your existing brake system or you can go to a hand brake which is independent to your brake system.
the hand brake however needs to be separated from the pedal.
wubanga
Feb 13, 2012 07:12 AM
boomslang
48
Sep 18, 2009 01:31 PM
alscrx
May 9, 2008 04:34 PM
CNSK
Jul 24, 2007 05:58 AM
