92 EH3 door trigger wire or wires....confused
I'm in the process of installing a stealth alarm in my 92 EH3. The problem is I'm trying to figure out which door trigger wire or wires do I need to tap the alarm into? I found the GRN/RED coming from the passenger door, followed it along the seat bottom and up the drivers side to somewhere behind the fusebox. Now I also found the driver side GRN/BLU and followed it up to the same are behind the fusebox. I checked continuity on both, they are separate, the passenger door did nothing on the drivers side test and the drivers side did nothing on the passenger side test.
So am I safe to assume that I need to tap into both of these wires to make sure that both doors would trigger the alarm? Or does the Passenger side catch both doors?
your door trigger will be Light Green/Red which is a negative trigger found in the drivers side kick panel. It will control all your doors other then your trunk which is Green/Black with 2 silver dots found above fuse box in a blue connection which is a negative trigger
Thanks, I found it, actually found both, I wanted to find these wires away from the fuse panel. The alarm is nowhere near the fuse box and only 2 wires run relatively close. Want to make thieves hunt for it if they want to try and take my car.
Dub C
Audio / Security / Video
Mar 17, 2006 10:33 AM
