Transmission & Drivetrain Gearboxes, Differentials, Clutches
swap kit flywheel
Old Jun 28, 2011 | 10:02 AM
cfisher85's Avatar
Default swap kit flywheel
i have a h22a in my 97 civic with a grs 5 speed trans and i have herd there is only one company that makes flywheels for this swap and that is evloution can anyone tell me different
Old Jun 30, 2011 | 08:44 AM
Gearspeed-Performance's Avatar
Default Re: swap kit flywheel
The Evolution H2B flywheel was specifically engineered to work with their kit and is different from your standard flywheel. Are you trying to use the flywheel for another H2B kit?
Old Jun 30, 2011 | 10:16 AM
MR.johnson's Avatar
I can't tell if he has a swap now or asking if h2b is buying a flywheel.
Old Jul 6, 2011 | 05:25 AM
cfisher85's Avatar
sorry for the wait im really busy with my job i have a 97 civic si with a h22a and a acura gsx 5 speed tranny i was replacing the clutch and found that when i pulled the tranny out i need a new fly wheel two ordered one from fidanza flywheel for a h22 and it was much bigger than the one i already had so i was lost at that point then sent it back and ordered one for a b series tranny and it didnt fit either
Old Jul 6, 2011 | 07:25 AM
Your inbox is full
What H2B kit do you have? Some of them will use a spacer to adapt a certain flywheel to work and Evolution makes their flywheel to work with their kit. Find out which one you have so you know what application you can use.
Old Jul 6, 2011 | 07:52 AM
Here are a couple kit examples:
http://www.quartersportsdrag.com/Kit_Contents.html
http://evoindusa.com/evoauto1/index....products_id=19
Old Jul 6, 2011 | 03:49 PM
cfisher85's Avatar
Thanks I have a spacer plate between the motor and bell housing of my tranny its just a plate that lines up holes for the bell housing studs to line up to the flywheel I think was a be series with a h series bolt pattern
Old Jul 6, 2011 | 07:45 PM
Can you find out from previous owner what kind of kit it is?
Old Jul 6, 2011 | 08:34 PM
MR.johnson's Avatar
cant you resurface your flywheel?
jdm knight
Dec 14, 2009 10:23 AM
PrestonCRX
May 13, 2006 06:59 AM
Preludes'R'Us
Nov 12, 2005 10:56 AM
bboylito
Dec 14, 2004 09:05 PM
torkcm
Apr 9, 2003 10:20 AM
