91 crx si, in dire need of tuning info
Have been looking for a few days, for how to set up the ecu for tuning, and have been able to find absolutely nothing in the way of a full explination in one place. I understand it needs to be chipped, i'll need a wire to connect my computer to the ecu and will need software, BUT, what i don't understand is what i need, and where to get it. All i know so far is that it has a pm6 ecu and its stock, boost is on the way, literally, in the mail, full set up, and i won't be able to tune it b/c no one wants to put any good information in one spot!
any information would be much appreciated, thanks.
hondata.com s400 is the sh*t ...usb hookup real time editing all sorts of base maps for common setups available. most tuning shops can install for you. they provide instructions if you wanna tackle it yourself
If you stay obd0 Turboedit, if go obd1 you can use chrome, ec tune, neptune, or hondata. I use neptune, and I have never heard of a hondata s400 maybe it's new. Check out hrtuning.com and moates.net, they have tons of good info on tuning.
^This. I use Neptune also in conjunction with a tunerview.
But if you haven't found a tuner yet, I'd find one, and I don't mean some fly by night tuner with only a hand full of cars in his belt. After you find one, get his recommendation on what software to use.
Go here:
http://forum.pgmfi.org/
http://forum.pgmfi.org/viewforum.php...6a1083f628c3f1
Do some research....
Im in central ky. I wound up surfing the **** out of pgmfi and finding a lot of good stuff, i decided to stay obd0 and went with an ostrich 2.0 and a hulog. Only problem i'm having now is that when i try to datalog i get really strange values. Like sitting still it'll say like 150mph, 35psi boost, 200:1 afr, all kinds of crazy ****, I'm gonna check the connections and soldering to the board and make sure its connected correctly, but it has been nothing but a headache since i got everything going, starting to think i should have just went obd1 and sucked it up >.<
fasst
Engine Management and Tuning
Oct 31, 2009 04:00 PM
