Gsr idle problem fitv?
Old Jun 27, 2011 | 06:43 PM
TurboTeG4's Avatar
Default Gsr idle problem fitv?
Very recently i started having a idle problem, my idle was set at 1k but now in neutral sometimes it goes from 1k to 1500 rpms.
I have screwed down the valve in the fitv, now the surge has decreased but is still there. The surge is not constant, sometimes it holds 1500 rpm for quite a while.
With the engine fully warmed up I still have suction on my bottom port in the throttle body. If I cover both holes in the tb my rpm decreases but the engine still runs fine.
Should I order a new fitv or is this a vacuum leak issue?
Edited
I ordered a new fitv the old one the needle wouldnt move even after putting near boiling wAter in the coolant ports of the fitv
lsxtreme81
Apr 20, 2007 05:39 PM
R. Mack
Jun 1, 2005 07:55 PM
Takashi1978
Nov 27, 2004 06:42 AM
CRX-SIR
Sep 20, 2004 06:00 PM
ponykillergsr
Dec 20, 2002 06:01 AM
