Issues with my 95 automatic dx 2 door - CEL code 0 and cluster gauges don't work
Old Jun 27, 2011 | 07:11 AM
Copeland_m's Avatar
Default Issues with my 95 automatic dx 2 door - CEL code 0 and cluster gauges don't work
Everything is stock, My ecu is reading code 0, My cluster gagues don't move, but all the lights come on. And on top of all that my 9th 10th 18th 19th 20th 21st and 22nd fuses show they are getting no power. According to my diagram of the under dash fuses most of those are for my headlights, which work... just fine...
Another little tidbit is that whoever had this car before me installed a sound system and there is a lot of what looks to be shoty work under the dash. Was wondering if anyone here had some advice for me to get everything up and running? Also was wondering if the bad wire job could cause the ecu error and the cluster issues. Thanks in advance, Mike.
Old Jun 27, 2011 | 07:17 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Issues with my 95 automatic dx 2 door.
Code 0 (defined by CEL remaining on steady both without and with the service connector jumped) - indicates ECU power or ground problem when engine will not start; begin by checking the three main relay fuses and the G101 ground attached to the thermostat housing.
Old Jun 27, 2011 | 07:24 AM
Copeland_m's Avatar
Ive checked every other fuse and everything, was wondering if bad wire job could produce the code, want to know before I run out and get another ecu.
Old Jun 28, 2011 | 11:56 AM
Copeland_m's Avatar
bump.
Old Jun 29, 2011 | 10:37 AM
Copeland_m's Avatar
Anyone?
Old Jun 29, 2011 | 06:37 PM
94EG8's Avatar
Seagull Management
Check the ground on the back of the thermostat housing on the engine, make sure it's clean and tight.
Old Jun 30, 2011 | 06:51 AM
Copeland_m's Avatar
Yes the ground is tight and clean. There is another wire that goes into the little wiring hose compartment next to the ground with a little yellow fuse in it, I don't know if that's important but i figured i should add all the info i have.
Old Jul 1, 2011 | 03:56 PM
Copeland_m's Avatar
bump
Old Jul 1, 2011 | 06:25 PM
apexi_rsx's Avatar
ecu could be fried... as they said either power or ground problem to the ecu or ecu is fried. if u know a friend with an ecu to borrow try that.
Old Jul 1, 2011 | 07:54 PM
Copeland_m's Avatar
Ok well what of my other problems? I gotta get a new ecu because all my friends race their hondas and they are manual where as mine is auto because its for my girl.
Old Jul 3, 2011 | 06:00 AM
Copeland_m's Avatar
bump
Old Jul 4, 2011 | 06:49 AM
Copeland_m's Avatar
Default Re: Issues with my 95 automatic dx 2 door - CEL code 0 and cluster gauges don't work
Bump
Old Jul 4, 2011 | 07:06 AM
94EG8's Avatar
Seagull Management
Try another ECU, a manual ECU will start the car fine.
Old Jul 5, 2011 | 08:30 PM
Copeland_m's Avatar
the car starts
there is no real issues except what i outlined.
Old Jul 5, 2011 | 08:35 PM
Former User's Avatar
I'm not convinced that you know how CEL code 0 is defined. If the service connector is not shorted with a jumper wire, does the CEL remain on steady with the key in ON(II)?
Gauges - check whether 10A dash fuse 15 is blown.
Old Jul 6, 2011 | 07:57 PM
Copeland_m's Avatar
yes. No matter what, the cel is on.
Copeland_m's Avatar
9th 10th 18th 19th 20th 21st and 22nd fuses show they are getting no power as well.
Old Jul 6, 2011 | 08:23 PM
Check for a short in the service connector and CEL wires.
Old Jul 6, 2011 | 08:24 PM
In general, dash fuses don't get voltage unless the key is ON(II) or the light switch is on.
Old Jul 7, 2011 | 03:14 PM
Copeland_m's Avatar
Sorry to sound like such a noob, but how do I check for the shorts? and I'll re-check my fuses.
Love-MY-honda
12
Feb 25, 2011 08:56 AM
sskracing
13
Aug 10, 2010 08:52 AM
chad
Apr 13, 2009 06:43 PM
ma_rio44
11
Jul 15, 2007 09:24 AM
civicguy167
10
Mar 13, 2006 07:40 PM
