Crank pulley bolt tricks
Old Jun 26, 2011 | 05:11 PM
beansandrice's Avatar
Default Crank pulley bolt tricks
There is no real "trick"! use a good impact gun.
For you backwards thinking dumbasses that recommend putting breaker bars on the bolt and bumping the starter you must be thinking about clockwise rotation engines.
Try this trick on a counterclockwise (most every honda auto) engine and you will tighten the bolt even more.
Chain straps will jack up the pulley and the Hex tool is good but you will have a bear of a time using one.
Impact ftw.
Old Jun 26, 2011 | 06:51 PM
D16SiHatch's Avatar
Default Re: Crank pulley bolt tricks
even a GREAT impact with a beyond sufficient compressor behind it still won't take off some of the tightest bolts. the tricks exist for this reason. (and i suppose people that don't own air tools lol)
valid point about the geniuses who bump the starter and risk shearing the bolt off though
Old Jun 26, 2011 | 11:21 PM
~sp33~'s Avatar
EFB055
Chocking the flywheel with a lock works to brace the engine if you're having trouble. Just a tip for those who haven't worked out that an impact gun is best yet. The flywheel chock also works nicely when you're torquing the bolt to spec.
Old Jun 27, 2011 | 03:37 AM
garthjenkins's Avatar
I just used a breaker bar and some PBblaster
came off after just going back and forth for a bit
Old Jun 27, 2011 | 04:26 AM
1990edsedan's Avatar
Better to use heat (torch) and get the bolt hot. Then hit it with the impact gun. It will come off like butter..
Old Jun 27, 2011 | 05:55 AM
Wdbjr12345's Avatar
A 1in impact gun never failed me but before I used to buy a tool from honda specificly made for hondas to hold it steady and use a 5ft breakerbar.
Old Jun 27, 2011 | 08:30 AM
ThatRicerDaniel's Avatar
I always just lock the flywheel but if the trans is still attached impact is the best. You can always rent an electric impact from home depot for super cheap if you dont have access to air..
Old Jun 27, 2011 | 12:38 PM
Electric impacts are about as good as a stick of butter in a knife fight.
Old Jun 27, 2011 | 02:01 PM
soooooo true
air all the way
fastdohc
Jul 27, 2010 07:14 PM
clayne
Oct 19, 2006 10:25 PM
Jamez
Mar 16, 2004 08:11 PM
vultron
Aug 9, 2003 09:59 PM
youngkow
Nov 22, 2002 01:21 AM
