brembo brake swap
Please take a look at the FAQ's and Guidelines before posting a new thread. It contains a majority of the commonly requested topics.
Sure. It is deffinantly not worth the price and heres a few reasons why. Is your car fast enough and do you track your car to fully use the potential of the brakes? Not only do you need the brake swap, you need custom axels if you use the type r hubs, the itr lower control arms. The lower control arms are wider than ours by around 15mm. You would need 5 lug wheels unless you redrilled for 4 lug and had custom brackets made to fit the larger caliper. Also advanced auto parts wont have brake pads for you. Your stock brake booster im sure wont be large enough to push the pads. Go through through the facts and get a set of legened calipers. That swap is more cost effective.
hey thanxs for info i just went out and got rsx brake parts i hope its a easy install, thanks again.
FXAutodesign
13
Feb 29, 2012 08:02 PM
speedfreak44
Sep 20, 2009 11:29 AM
