Which brake lines to buy
Old Jun 24, 2011 | 11:52 AM
dc5itracer's Avatar
Default Which brake lines to buy
Hey fellas well I got a 91 Si with da integra hubs and brakes I want to order some goodridge ss lines but not sure if I should order civic or integra ones any info b appreciated
Old Jun 26, 2011 | 07:15 AM
dc5itracer's Avatar
Default Re: Which brake lines to buy
Bump anyone know
Old Jun 26, 2011 | 11:12 AM
EKwreckRLS's Avatar
you need to make sure the rear brake lines are made for disc or drum brakes per your application.
The only other issue that I can think of is the length might be wrong if you order for a hatchback but need them for a sedan or whatever.
Old Jun 27, 2011 | 07:37 PM
dc5itracer's Avatar
Well ima install integra rear brakes
Old Jun 28, 2011 | 11:09 PM
EKwreckRLS's Avatar
then make sure you get brake lines for rear disc application.
Old Jun 29, 2011 | 02:10 AM
90civicstdgold's Avatar
You will need the integra ones because they are a tad bit longer than a civic brake line
Old Jun 29, 2011 | 02:22 AM
ef92b's Avatar
^ what he said.
it's what i have too with the integra brake set-up as yours.
Old Jun 30, 2011 | 01:30 PM
dc5itracer's Avatar
Cool thanks guys much help you been all
NOOdS
Sep 11, 2012 02:03 PM
jefe
30
Dec 11, 2004 12:41 PM
streetdreams420
Aug 23, 2003 07:06 PM
DarkCyde SI
Mar 20, 2003 07:56 PM
