Sandwhich Plate with Oil Cooler/Rel. Kit
Currently I am running a Glowshift oil filter sandwich plate to feed oil to my turbo, and plug in sensors for oil temp/pressure.
I do not have an oil cooler yet but I am looking into purchasing one soon.
Now with most oil coolers come the filter relocation kit with the feed plate for the cooler.
I'm wondering if I can run my current sandwich plate for the turbo feed etc... in conjunction with the relocation kit and feed the cooler?
Thanks!
Thanks!
If it were me, Id tee off the oil pressure switxh for the feed and sensor, then use the plate for the oil cooler.
Heres a kit and directions:
http://www.xenocron.com/remote-oil-p...70db84f45bc1d0
Heres oil coolers on the cheap:
http://www.votionspeed.com/servlet/t...ers/Categories
When you say oil pressure switch are you meaning the sending unit?
My only concern with that is that the lines are 3/16" and the fittings for the cooler are 1/2". In that situation would you use adapters?
Also if I'm using two ports on the sandwich plate for the cooler wont the pressures equalize and restrict any flow?
I appreciate your help!
hndacord02
May 30, 2010 07:23 AM
creechrr
Jan 2, 2007 02:04 PM
Black R
Jun 27, 2004 05:54 PM
DamonBoost
Jun 16, 2002 04:24 PM
