Can I make my ecu re-learn for alt?
Car '96 EX 5-speed
I have a high output alternator in my car that is bigger than stock. The drag on the engine can make the car idle drop down pretty low especially if I have the A/C on too. Is there a way to reset the ecu for this?
Just disconnect the negative terminal battery for 10 sec and hook it back up. Start the car up and let it idle for a min or two w/o touching the gas pedal just so the ECU can relearn what the changes were.
You cannot teach an ECU, the ECU is programed and gets Info from multiple sensors. Once you turn the ignition on, the ECU scans thousands of times a second. If it hasn't detected the new part you added, than resetting it will do. zero.
To make that relearn process work, the OP will have to convert to OBD1 and get his car tuned by using a chip P28 or a OBD1 P72 ECU.
I'll try this but I am pretty sure in the time I have had this I have had the battery disconnected.
OP if you find that your idle drops with load it could be a dirty IAC valve. That is what it's function is. When there is an electrical load on the engine at idle. The ECU will change injector and ignition timings along with the amount of air that will bypass the throttle. (IACV)
Also try resetting your base idle. There is a screw in the throttle body that sets a base idle speed of 500 RPM with the IACV disconnected. You may need to add a little air to it to compensate for the increased load. The IAC can only add to the base idle, and it can only add so much.
