bogging B18a
Old Oct 1, 2002 | 01:47 PM
robbin's Avatar
Default bogging B18a
My b18a in my 90 teg has for quite some time, bogged occasionally at very low rpms when moving from a standing start. I can get it rolling fine, but when I go to accelerate, the engine bogs heavily and I have to disengage the clutch to keep from stalling. I don't recall this problem ever happening once the engine was warm, but I'm not 100% sure.
I figure it might be either a fuel or a spark problem, and I remembered a while ago my mom took my car in for an oil change. She said the guy told her that my spark plug leads were shorting out. I ignored it because I just figured he was trying to sell my mom some spark plug wires or something, but could that be related to my problem?
Thanks
Old Oct 1, 2002 | 06:55 PM
lazy bum shaughn's Avatar
Default Re: bogging B18a (robbin)
That's more than likely your problem, either that or bad mounts.
Old Oct 1, 2002 | 10:34 PM
robbin's Avatar
Default Re: bogging B18a (Breakdancer)
Yeah, I thought of that too, and I'm reasonably certain my mounts to suck. Maybe I'll try to fix those over the winter. I tried to buy plug wires today but the first place I went to didn't have them and I didn't have any more time. I guess I'll just fix things until the problem stops.
Old Oct 2, 2002 | 09:47 AM
93_civic_EX's Avatar
after u replace the wires, if the problem is still there, u should try testing the tps(throttle position sensor) on the throttle body. i remember when my tps went bad the motor kept bogging off like u explained. i ended up replacing a bunch of **** before i found out that the tps was the reason for the bogging
Old Oct 3, 2002 | 08:07 AM
robbin's Avatar
Default Re: bogging B18a (93_civic_EX)
What should I check for on the TPS. Is it something obvious or is it a little harder to find because my tps and throttle cable get checked every time I get my car teched for autoX, but it's certainly possible that we're all missing something.
Brown328
Apr 4, 2013 10:27 PM
BLU CIVIC
Mar 25, 2009 09:09 PM
Spectre2004
Mar 2, 2008 04:04 PM
HTn00b
43
Nov 8, 2006 02:35 PM
CRiSP
Jul 4, 2005 10:23 AM
