SI EG leaking oil, need help
Old Jun 21, 2011 | 08:09 PM
Nocturnal's Avatar
Default SI EG leaking oil, need help
I have a 93 EG SI that is leaking oil. I had the timing belt, water pump and cam seals etc. changed roughly at roughly 110k miles.
I'm at 170k miles now.
Unfortunately the engine is dirty so it's really hard to pin point exactly where the oil is coming from. Is there anything that I can do to figure out where the oil leak may be coming from?
I can smell the oil being burnt as I drive. There is no noticeable smoke coming from the exhaust as I drive.
Any ideas?
Old Jun 21, 2011 | 08:30 PM
EJeff8's Avatar
Default Re: SI EG leaking oil, need help
Common problem is the Dizzy o-ring. Check to see if the top of your tranny is being stained in motor oil. Could be a faulty valve cover gasket, really any number of things. Doesn't hurt to look for oil stains though, or at least feel and sniff around for oil residue.
Old Jun 21, 2011 | 08:31 PM
Doofus's Avatar
I just did my t-belt at 135k and when I changed my seals out, they weren't leaking. I doubt the new seals are leaking after only 60k unless the tech that worked on your car got lazy and didn't change them.
If I were you, I'd check the obvious places like the distributor o-ring and vtec solenoid gasket for leaks.
lolv8s
K Series
Apr 14, 2016 01:29 PM
Looney2002
Acura TL, RL & ZDX
Mar 24, 2013 05:08 PM
davey5300
Aug 16, 2009 07:29 PM
masijdm
11
Jan 9, 2009 09:21 PM
hotstuffjsn
Mar 9, 2005 07:11 AM
