honda accord 98 cooling problems
i just recently changed my radiator because it had a big leak of coolant and started to smoke a lot nd i thought my car wouldnt get as hot as its getting right now the fans dont work when the car is turned on but wen i put the a/c they do work BOTH of them when i stop in a light for example temp of the car rises but then when i drive. it goes down really quick i have no clue wats goin on with it.
how can i solve this problem? any advice?
ive been told tht is the radiator fan switches dat got burned nd they dont work i have to change those nd the thermostat but i have no clue on how to change those 2 things?
Did you bleed the coolant?
While driving (moving) the temp is fine? Then why do you think the t-stat is bad?
Could be the ONE fan switch is bad, but if the coolant isn't getting to it....bleed the air out....it never has a chance to work properly.
Do what you want.
Do what you want.
Skoalbandit
Jun 16, 2012 02:34 PM
edcpus
Jul 21, 2011 07:24 AM
