Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Cel p0740???
Old Jun 21, 2011 | 09:24 AM
ldyjam's Avatar
Default Cel p0740???
My daughters 2001 Honda Civic has a P0740 code as well but there is no difference when driving it. We have reset the code 2 times and it always comes back on once she goes over 45.
Old Jun 21, 2011 | 05:12 PM
lazlong's Avatar
Default Re: Cel p0740???
P0740: Lock-up control system (auto trans)
If there are anymore codes diagnose them first.
How long has it been since the last transmission service (fluid change)? Does the transmission fluid look dirty? Does it smell burnt?
Drain the fluid through a strainer. Is there any debris? If there's debris you're trans is going and you will probably need a new one soon.
To go any farther you need a pressure gauge and adapter for the transmission or you could just replace the solenoids but, that's expensive ($400) and you may just be throwing money away if it's the whole trans going. If you do have to replace the trans go with a 2004-2005 as they went with better clutch materials and pretty much fixed the problems these trans were having.
Old Jun 22, 2011 | 04:12 PM
bryse68's Avatar
need to replace transmission assembly unfortunately. do not replace solenoids or perform any transmission flushes, it wont fix it. the only way is to replace the transmission assembly.
hexavolt
Transmission & Drivetrain
Dec 27, 2017 09:09 PM
1yesfan
Mar 12, 2015 02:31 PM
jmh51193
Jan 12, 2015 04:21 PM
buugiewuugie
Sep 21, 2012 11:22 AM
hondarsw
Feb 17, 2007 01:46 PM
