FOR SALE OR TRADE 1987 BMW 325i VERT
87 325i vert
5speed
clean title
current tags
engine was built back in 2004 by last owner.
trans was replaced 3 months ago by Castros in NoHo, CA
Comes with : BBS RD037 15x7 with 4x100 to 4x108 17mm adapters, Euro Bosch Smilies with DDM 55w 6k bulbs HID kit. Chipped 153 ecu , Euro rear plate filler , Custom exhaust done by Castros in NoHo. Spintech with dual 3inch slanted stainless tips ( installed same time as the trans ) I replaced the top with a used one from a parted out vert 2 months ago. Aftermarket radio with USB and AUX ports , 4ch. amp.
Work ive done to the engine. I replaced the headgasket along with headbolts , new 71* thermostat ( allways stay at 1/3 temp ) replaced coolant temp sensor , valve cover gasket , valve cover breather hose to the TB, and spark plugs.
Ill be replacing the Dizzy and rotor along with plug wires soon.
AC worked when I got the car but the belt was bad so i cut it.
No leaks , The power steering dosnt work due to the hose leaking .
Needs some TLC , bumper are tucked.
Will come with , pink slip , front newish totikio front shocks , and Racing dynamic rear touring springs.
Depending on time , the car will be MAF kitted , there will be a upcharge.
Asking 3500 or best offer. Open to trades but must be 5speed.
Not selling because i need , its moreless a feeler. THANKS!
wheel adapters
car has a blue top now with a sorta clear window.
5speed
clean title
current tags
wheel adapters
thanks guys. Id be willing to trade for a dc2 gsr :D
if you guys dont know , there old e30's still pack some good punch
stock Hp rating is 171hp and 170tq , its RWD , 5speed its chipped!
integraboi1010
Jun 25, 2005 07:31 AM
