Transmission & Drivetrain Gearboxes, Differentials, Clutches
auto tranny jumps in reverse not a blown mount!
Old Jun 20, 2011 | 05:46 PM
santii7's Avatar
Default auto tranny jumps in reverse not a blown mount!
what up ht! okay so i bought a 97 lx 4dr automatic. had a blown motor, replaced it wit a 99 ex y8 but kept my 97 lx auto tranny. so heres the deal when i put it on reverse the motor/tranny jumps up like pretty ugly but when i put it in drive its fine. it feels like a blown mount the they are all good! the tranny drives fine in both drive and reverse its just when i put it in reverse does it jump. oil in the tranny in new and filled to the right amount sooo idk much really when it comes to auto tranny so im hoping someone here knows why it does this.
thanx ht!
Old Jun 20, 2011 | 05:56 PM
santii7's Avatar
Default Re: auto tranny jumps in reverse not a blown mount!
bump! wheres the auto tranny gurus lol
Old Jun 21, 2011 | 07:00 AM
David @ Synchrotech's Avatar
Double check for external problems: Idle RPM, loose bolts, worn mounts, etc. See what happens if you hold the brake while in reverse and stab the gas - Does it jump and bang? If it seem fine and only has harsh engagement when shifting to reverse, it could be a worn 4th accumulator or sticking servo valve in the transmission.
Old Jun 21, 2011 | 07:43 AM
santii7's Avatar
Thanx alot bro. I found out at the problem was, I was in the middle of doing the iacv so without it being plugged in it made it shift into it aggressively but I did the iacv and now it's fine.
Old Jun 21, 2011 | 12:43 PM
94EG8's Avatar
Seagull Management
You need the Y8 tranny. You will start throwing a P0700 and P0715 code eventually, sometimes it takes a week or two to show up though, and it will shift a little funky. I have noticed a delayed engagement when shifting into reverse as well.
Old Jun 21, 2011 | 02:01 PM
santii7's Avatar
Maybe.. It's been fine tho shifts good too. Only time will tell lol
Old Jun 21, 2011 | 02:12 PM
If you are using the original 97 LX transmission and PCM it should not set the codes. Usually the code problem only happens when the PCM and transmission are mismatched.
Old Jun 21, 2011 | 02:19 PM
santii7's Avatar
Yea I'm using the original ecu harness and tranny I don't have any codes popping
santii7
Jun 21, 2011 04:24 AM
murmur9
Mar 5, 2006 06:41 PM
fast2camciv
Nov 13, 2003 12:09 PM
