5mt prelude tranny fluid suggestions?
Old Jun 20, 2011 | 04:08 PM
01bb6boy's Avatar
Default 5mt prelude tranny fluid suggestions?
hmmm so,, im a newb at this. and got a quick question for all you fellow preluders and honda-ers lol, so here goes.... ermmm.. what kind of transmission fluid would you guys recommend? i have a 5th gen 5MT prelude, and im sure the previous owner never bothered to change it. if anyone can suggest something please let me know. thanks!!
Old Jun 20, 2011 | 04:11 PM
nus_dogg's Avatar
Default Re: 5mt prelude tranny fluid suggestions?
I'm currently running Amsoil GM Syncromesh in my T2T4 LSD trans with no problem, and it shifts like butter. But I was told that those GM Syncromesh is not good for my FACTORY LSD unit(it even says it on their bottle), so I'm going to switch it back to Honda MTF soon.
As for you, you can go with Honda MTF, Amsoil GM Syncromesh(most ppl recommend this brand), or Redline Gear Oil(I heard it's pretty good).
Old Jun 21, 2011 | 04:49 AM
1GPlusSH's Avatar
Originally Posted by 01bb6boy
hmmm so,,
lol,
... ermmm..
https://honda-tech.com/forums/showth...&highlight=mtf
plenty of input in this post for you to make up your mind
Old Jun 21, 2011 | 06:51 AM
razorlude's Avatar
lsd or non lsd gb using different type of lube...don mess it up.
Old Jun 22, 2011 | 08:35 AM
professorwrinkl's Avatar
i would say just use Honda mtf, but are you trying to track your car or something?
Old Jun 22, 2011 | 05:23 PM
01bb6boy's Avatar
well im guessing my syncrhos are messed up, reverse and 4th are a bit ruff at times, i live in canada too so it gets cold here at times, and my car is a dd for now, thinking of taking her to the track once i do a few things to her first, but i was reading about gm synchromesh vs the honda mtl. umm now... how do you replace your mtl? do you just add the new stuff in with the old, like mix them? or compeltly drain the current mtl and fill it with gm synchromesh or etc..? never done this befor and this is my first car, all this still new to me.
Old Jun 22, 2011 | 05:35 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Drain. Fill. Enjoy.
like so:
Get all 4 wheels off the ground. This requires 4 jack stands. The car has to be level.
Remove the fill plug FIRST. It's a 17mm bolt that's slightly above axle level. It'll be located next to the passenger side axle hole kinda.
Then remove the drain plug. You stick a 3/8'' ratchet on it and remove it. It's a square head bolt. It's a good idea to use a new drain plug washer. It's the same as the oil pan plug washer.
Let the smelly *** fluid drain out completely. Then replace the drain plug. Don't tighten it too much or you'll crack the trans case. IIRC, spec is like 35LBS or something.
I use a funnel with a flexible hose on the end to refill the trans. You just pour the lube into the fill plug till it dribbles out. I think preludes take like 2.5 quarts? Then replace the fill plug.
ENJOY!
Old Jun 23, 2011 | 02:28 PM
01bb6boy's Avatar
awesome... thanks B serious, guess i will be doing it this weekend or next. also, which mtl would u suggest be used? since everyone says GM sm, amsoil sm, honda mtl, list goes on n on, does it really just come down to preference? or does it really make a difference on which mtl you use?
Old Jun 23, 2011 | 07:55 PM
Yuyodrift91's Avatar
.....Why can't people search anymore?
Old Jun 28, 2011 | 06:02 AM
the fluid lubricant pump i got from napa works great for changing the mtf, you just screw it on to the honda mtf bottle or whatever you use, and after you have drained the trans completely you just pump two quarts in and bolt it up!
new washers are recommended by honda everytime you change the mtf.
Old Jun 28, 2011 | 07:07 AM
B serious's Avatar
It has a lot to do with preference. I use honda mtf or redline synchromesh if there's a slight grind issue.
Old Jun 30, 2011 | 08:24 PM
flyrod's Avatar
I just drain it then put in 2 quarts of mtf through the vent. Takes maybe 10 minutes.
Old Jul 1, 2011 | 04:53 AM
oranginal's Avatar
i would say stick with the honda stuff.
Would an aftermarket LSD make a difference in the choice?
Old Jul 1, 2011 | 07:39 PM
InvaderTrax's Avatar
Helical, no. Clutch type, yes.
JDMCRX
Jun 5, 2004 08:46 PM
importboi22
Aug 3, 2003 10:20 PM
wicx
Oct 17, 2002 11:13 PM
B18C5-EH2
Dec 16, 2001 04:52 AM
Greyout
Nov 23, 2001 08:18 PM
