engine bay cleanup
Old Jun 20, 2011 | 02:26 PM
gnxpro24's Avatar
Default engine bay cleanup
can I get rid of the charcoal canister safely and without any adverse affects on the car?what do you do with the hoses leading to it then
Old Jun 20, 2011 | 03:54 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: engine bay cleanup
You can, the worst side effect will be pressure build up in gas tank (can be eliminated by vented cap). Plug/ cap all the lines obviously. Don't you have inspections in PA? That should be enough to fail you.
Old Jun 20, 2011 | 04:29 PM
4drEF's Avatar
Keyboard Humorist
It might look a little better, but how often are you popping your hood to look at the engine bay?
Old Jun 20, 2011 | 05:57 PM
gnxpro24's Avatar
would it be dangerous due to vapors to relocate it under the dashboard?
Old Jun 20, 2011 | 06:14 PM
DO IT ON ALL FOURS
If you like cruising with gas vapors, then be my guest.
Old Jun 20, 2011 | 06:19 PM
gnxpro24's Avatar
if I eliminated it what would I do about the sensor that is wired in junction with the one line that runs to it?
Old Jun 20, 2011 | 10:27 PM
floww's Avatar
just leave it there, aint no harm done i would figure.
hondacrx6's Avatar
i like mine!!
Old Jun 21, 2011 | 02:58 AM
DO IT ON ALL FOURS
The "sensor" (actually a solenoid/valve) is just for the purge valve on the canister - you could just leave it there, I have just left it plugged in but removed all lines to it from the manifold.
Old Jun 21, 2011 | 10:26 AM
gnxpro24's Avatar
and this doesnt affect the ecu? doesnt it weird out?
Old Jun 21, 2011 | 12:11 PM
DO IT ON ALL FOURS
It's not an active "sensor". As stated before it's not even a sensor... The computer doesn't have a checking system in place to be sure it is even operating properly. It just says "hey you, open up"... Kind of like the Cops.
Old Jun 21, 2011 | 12:20 PM
gnxpro24's Avatar
wow well after I get my car inspected I might eliminate it. In 3 years I could make my car an antique and never have to get it inspected again. any ideas where to get a vented gas cap to fit our year civic?
Old Jun 21, 2011 | 12:34 PM
DO IT ON ALL FOURS
Any parts store typically sells vented, but if you can't find one then no big deal. You will just hear a hiss when you take off your gas cap. I personally ALWAYS remove my canister because I turbo everything.
boostedem123
Apr 13, 2016 05:02 PM
clemsoncb7
Jun 7, 2005 03:35 AM
teg92
Apr 6, 2005 11:21 AM
gnar kill
Feb 28, 2005 10:47 PM
hOndafienD 04
Oct 19, 2004 12:21 PM
