Cooling and Radiator Fans not coming on even with A/C switch to ON
I have a 1992 accord, both of my fans will not come on even with the a/c switch to on. I jumpered the fans throught the condenser relay connector ylk/blk and red, and both fans will come on when I turn the A/C switch on. So, I thinnk the fan motors are okay. I checked the no. 2 fuse and it is good. I am lost as to what is wrong?
Wow, I saw this same thread somewhere else....let's start with the easy things. Jump thermo/switch a on the t-stat, key on, do BOTH fans run?
Does the ac work?
Does the ac work?
hi poorman212 ...
it is the same question on different forums. so, how do I jumped the thermo/switch A? Do I disconnect the switch and jumped the connector? I am still not sure where switch A is located, but assume it is a 2-p connector, correct?
Thanks!
Thanks!
i posted in a diff forum a similar problem.. still waiting ona response.. Cause my fans won't come on with the ac on or off .. im really confused.. im about to go jump that thermo switch right now to see what happens
update jumped therm switch NOTHING
my ac fan does not come on. ac does not work. i unplugged the connector at the fan and ran a hot wire and ground wire to 2 pin connector, still will not come on. 1994 honda accord
That obviously means the fan motor itself is not working. Pick up a new fan motor from the junkyard.
