oxygen sensor
is an o2 sensor for a sohc Honda the same as a b series o2 sensor? rywire sells an o2 sensor and says its for a d series and b series but other part manufacturers i look up the part number between the sohc and dohc dont match
OBD1 4 wire O2 sensors are all the same, with the difference only being the length of wire to the connector (and thus a different part number). Most universal 4 wire O2 sensors just use a longer length of wire so that it can fit more applications.
FYI do NOT buy the autozone "bosch" o2 junk. Get an NTK (made by NGK/OEM Honda) We have the universal 4 wire NTK for $79 http://www.hamotorsports.com/stntkoxse4wi.html
The bosch O2 is very slow in responding to air/fuel fluctuations while the NTK is fast responding which will help the ECU to make correct adjustments in closed loop.
