need basemap for s300
Old Jun 19, 2011 | 10:55 PM
hatche1's Avatar
Default need basemap for s300
Well i just got hondata s300 and wanted to know if someone could help me by setting me up with a good basemap for my setup. i have a d16y8 with eagle rods, srp pistons(stock compression), stock ports on head with isky valve springs, stock cam, y8 intake manifold, stock tb, omni 4 bar map sensor, rc 750cc injectors, log turbo manifold, turbonetics T3/t4 57 trim .63 a/r turbo, 3 in downpipe, 2.5 exhaust, and 38mm wastegate with 11lbs.
Old Jun 20, 2011 | 08:37 AM
hatche1's Avatar
Default Re: need basemap for s300
come on someone lend me a hand.
Old Jun 20, 2011 | 10:14 AM
mtber's Avatar
Contact the dealer you bought the system from to see if they can provide you with one.
Otherwise, consider paying for a good basemap from a reputable vendor:
http://www.phearable.net/shoppingcar...ware-c-40.html
Old Jun 20, 2011 | 09:38 PM
hatche1's Avatar
i was looking into getting a basemap for you but is your basemap really to to start off of and will it at lease start my car to idle and drive around so i can start tuning it? if the car doesn't start up is there anyway i can email you again and maybe you can tweat the map alittle?
Old Jun 21, 2011 | 03:44 AM
mtber's Avatar
Email/contact us for further details.
You should have a wideband oxygen sensor gauge to monitor your air fuel ratios before you do anything.
Old Jun 21, 2011 | 09:12 PM
hatche1's Avatar
yes i got a aem uego digital wideband.
Old Jun 22, 2011 | 04:33 AM
mtber's Avatar
Awesome. We have tuned several y8 setups with 4 bar map sensors etc.
A basemap shouldn't be an issue :-)
kfoster1234
Jan 28, 2017 03:10 AM
Skip01
May 18, 2014 07:52 PM
NonovUrbizniz
Jan 15, 2008 12:44 PM
dornon13
Feb 25, 2005 02:23 AM
