bad distributor?
Old Jun 19, 2011 | 04:17 PM
thebluecrx's Avatar
Default bad distributor?
there is a bad grinding noise under the distibutor cap. do ya'll have any idea? everything i have read is that i have to replace the whole distributor
Old Jun 19, 2011 | 04:31 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: bad distributor?
Why don't you pull off the cap and take a look?
Old Jun 19, 2011 | 04:57 PM
thebluecrx's Avatar
it started doing it on the way to my girlfriends house and want to spend time with her and not workin on my car hahaha
Old Jun 19, 2011 | 05:20 PM
dannysolis92005's Avatar
The rotor screw might be losE. Have your girl make you something to drink n chill with you while you check it out. Should take like 15 mins n you kill two birds with one stone.
Old Jun 19, 2011 | 05:34 PM
DO IT ON ALL FOURS
Have fun walking home then.
Old Jun 19, 2011 | 07:34 PM
thebluecrx's Avatar
theres a pretty good loss of power too if that helps at all
Old Jun 19, 2011 | 11:03 PM
BiG ChOr!Zo's Avatar
pics of said girlfriend...???
Old Jun 20, 2011 | 04:21 AM
DO IT ON ALL FOURS
I met her before and watched them wrestle - She is in blue and he is in red, now you see why he can't work on his car.
Old Jun 20, 2011 | 07:55 AM
thebluecrx's Avatar
haha your an ***. i took the rotor cap off and it looks fine i put everything back on and its making the grinding noise even more
Old Jun 20, 2011 | 08:15 AM
evanguy's Avatar
the bearing went in my dizzy about 3 months ago. just take the dizzy off and grab the little thing that goes into the cam and turn it if its all loose and broken feeling it probably is. i found an after market new one for 185$
oh yeah and every time the car would heat up or i went reved about like 4k it would shut the car off becuase the rotor was hitting and missing the posts in the cap the bearing was so bad.
Go_Kart_Driver
Apr 17, 2007 01:28 PM
trooper0641
Jul 9, 2005 12:22 PM
Matty.
Nov 13, 2004 10:25 AM
fe519
Oct 20, 2003 01:04 PM
RAWB
Jan 3, 2003 08:31 AM
