oil leaking from cam seal on timing belt side
Old Jun 19, 2011 | 08:53 AM
protopro88's Avatar
Default oil leaking from cam seal on timing belt side
so my car has been leaking alot of oil lately and saw it was leaking from the bottom of the cam seal. but when I drive the car it leaks alot. is it possible for the cam seal to leak that much?
Old Jun 19, 2011 | 09:07 AM
grumblemarc's Avatar
The Grumpiest
Default Re: oil leaking from cam seal on timing belt side
Is this a trick question? The cam seal is leaking. Who cares how much oil is leaking? Change it.
Old Jun 19, 2011 | 09:17 AM
protopro88's Avatar
I know but I don't know if the head gasket is leaking because it pools up on the headgasket
Old Jun 19, 2011 | 09:19 AM
delinquent's Avatar
are you sure it's not the vtec solenoid gasket?
Old Jun 19, 2011 | 09:22 AM
protopro88's Avatar
im talking about the cam seals on the other side of the head. next to the timing belt
Old Jun 19, 2011 | 09:24 AM
The Grumpiest
So if I understand this issue correctly, you haven't changed out a KNOWN DEFECTIVE PART because something else MIGHT be defective also but you haven't verified whether it is or not?
Old Jun 19, 2011 | 09:28 AM
protopro88's Avatar
yep. I just don't want to change the seals and then put everything back together and have it be something else. i guess ill just have to try it
Old Jun 19, 2011 | 09:33 AM
The Grumpiest
That thinking is just not wise. That would be similar to being and sick and NOT going to the doctor because he's going to tell you that you're sick.
Old Jun 19, 2011 | 11:41 AM
civickiller's Avatar
Nah, it's like not going to the dr when your sick because you think you have two different illnesses
Old Jun 19, 2011 | 12:04 PM
The Grumpiest
Either way you're still sick. Not going to the doctor won't make you well. Fix the immediate issue before worrying abuou what could be wrong
Old Jun 19, 2011 | 12:47 PM
And if it's the hg, your going to have to take off more.
So your saying you rather do everything to pull the head and shave the head then put it back on just incase it MIGHT be the hg. And waste the money
Old Jun 19, 2011 | 12:57 PM
The Grumpiest
If you think it's the headgasket at least do a compression test. As for the leaky seal you have no choice but to replace it if you want to stop spewing oil all over the place.
Old Jun 19, 2011 | 01:01 PM
The Grumpiest
Who's saying that? I'm saying that you need to fix the apparent problem. You know the seal is faulty. Replace it. There are other ways to check the integrity of the headgasket that don't require disassembling anything.
Old Jun 19, 2011 | 03:00 PM
That's what I'm saying too just in a more confusing way I guess, lol
Old Jun 19, 2011 | 03:18 PM
The Grumpiest
Oh. Yeah. I don't understand the thinking that I know somethings broken but I don't want to fix it in case I find something in worse condition.
journeyquest
Oct 3, 2011 04:07 PM
malink
Jun 4, 2009 07:35 PM
jerbear!
May 7, 2005 09:31 PM
Specialk
Jan 14, 2003 07:50 AM
