wheel pushed back into the fender.
Old Jun 18, 2011 | 06:48 PM
hatmanafro's Avatar
Icon6 wheel pushed back into the fender.
hey H-T..
i was wondering what you guys think about this. i have searched here and on g2ic and i guess it could be a bent lca but what im even more scared of is a bent subframe.
ive read about the front crossmember and radious rods having something to do with it.
what kind of things could i be facing. and what kind of solutions can you guys think of?.
i have yet to get under there and see whats wrong but i will do that soon.
Old Jun 18, 2011 | 07:33 PM
Aqualite_Solid's Avatar
Default Re: wheel pushed back into the fender.
Damn. It jus might be ur lca. When I broke a ball joint on my db7 it tweeked it jus like that. Any accidents or anything?
Old Jun 18, 2011 | 07:39 PM
hatmanafro's Avatar
well. im pretty sure the car has been in a wreck. and just a few weeks a go i smaked a curb.. :/
so yes.. im sure it has hit a few things
Old Jun 18, 2011 | 08:10 PM
racebum's Avatar
can't tell, car is too low for the suspension to be useful. possible the front subframe has shifted back.
what are the caster readings on the rack?
Old Jun 18, 2011 | 09:02 PM
hatmanafro's Avatar
im not sure. i havent been on the rack in a while. i have tried to align it myslef.. but thats on my driveway. lmao
Old Jun 18, 2011 | 11:12 PM
Uve definitely bent that lca then depending on HOW n how hard u hit. But lca aren't easy to bend.
Old Jun 19, 2011 | 06:41 AM
1998GsRIntegra's Avatar
I'm leaning towards bent subframe, fixable, but what a huge pain in the ***. I replaced one on a crx and that was enough for me. Good luck.
Old Jun 19, 2011 | 09:58 AM
hatmanafro's Avatar
How did you replace it? Cut and weld?
Old Jun 19, 2011 | 01:03 PM
hatmanafro's Avatar
Alright so i got a look down there just now and the lca and subframe look good to my relif.. But the front crossmember looks like ****. Its definetly bent. I want to try and adjust it using the radious rods. Is it doable?
Old Jun 19, 2011 | 04:30 PM
I don't think you'll be able to get it right with just the radius rods.
If I were in your place, I would either pick up a new cross member with radius rods, or look into a full traction bar setup. Obviously a new cross member will be much cheaper, but if you plan to do any kind of serious racing or you dont want to have to notch the cross member to be able to run a good header, a traction bar setup would be the way to go.
You kind of have to look at it as new used oem piece for about $80 or Full traction bar setup for $300+
If you are just dailying the car with a bit of drag racing here and there, I would just go with an oem piece. For me, it would be hard to justify spending the money on a traction bar setup if your not taking advantage of it.
Old Jun 19, 2011 | 04:34 PM
Oh and as far as fixing it goes (even though you've determined you dont need to), the whole thing unbolts, you just have to take a lot of **** appart to get it off. Basically all the suspension components on the front end, as well as disconnecting the steering rack from the steering wheel down by the pedal assemblies, and the rear motor mount.
Old Jun 19, 2011 | 11:20 PM
hatmanafro's Avatar
Thanks patrick. Yeah i was thinking about just hitting up the junkyard an picking up a new crossmember. I appreciate the info. And yeah. I just DD thw car with some playing around here and there. Not verry serious.
Old Jun 20, 2011 | 07:11 AM
If your talking about me...I'm not Patrick. Lol
Old Jun 20, 2011 | 08:04 AM
hatmanafro's Avatar
I coulda swore youre name was patrick gsr integra or somethin... My fault. Hahaha
Old Jun 20, 2011 | 08:10 AM
kaiba's Avatar
LOL, you got the wrong guy.
Old Jun 20, 2011 | 08:59 AM
hatmanafro's Avatar
Hahaha. Watever his name is. Thank you. Lmao
Old Jun 20, 2011 | 11:34 AM
Lol, no problem. You were probably thinking of PatrickGSR94. I haven't seen him on here in a while.
Old Jun 20, 2011 | 08:45 PM
hatmanafro's Avatar
yeah i guess so.. lmao..
SoFreshh
Jun 1, 2009 02:15 PM
Keebler
Apr 2, 2005 01:45 AM
GR_DC2
Suspension & Brakes
Jan 17, 2005 07:04 PM
Agent STFU
Mar 25, 2004 06:45 PM
Spade
Jun 20, 2002 07:43 AM
