Has anyone tried maching B16a2 Intake Manifold to accept OBD1 type IAT sensor?
Old Oct 1, 2002 | 11:05 AM
ElectronMan's Avatar
Default Has anyone tried maching B16a2 Intake Manifold to accept OBD1 type IAT sensor?
I would like to get the true intake temp reading rather than the reading before the turbo. I've noticed some people do this by getting the type r manifolds. I noticed on the stock manifold there is a notch where a IAT would mount but its covered up. Has anyone drilled it out and mounted a IAT there?
Old Oct 1, 2002 | 01:58 PM
Default Re: Has anyone tried maching B16a2 Intake Manifold to accept OBD1 type IAT sensor? (ElectronMan)
Old Oct 1, 2002 | 02:04 PM
boostaholic's Avatar
I've never tapped that section of the IM, but i don't see any problem in doing it. Just drill and smoothen out the right size hole for the IAT sensor and tap two holes for the screws that hold it down. Make sure you clean out the IM afterwards of any metal flakes and you should be fine.
Old Oct 1, 2002 | 02:15 PM
Gmedalion's Avatar
Default Re: Has anyone tried maching B16a2 Intake Manifold to accept OBD1 type IAT sensor? (boostaholic)
I tapped it with no problem
Old Oct 1, 2002 | 05:56 PM
turboex's Avatar
Default Re: Has anyone tried maching B16a2 Intake Manifold to accept OBD1 type IAT sensor? (Gmedalion)
just put your sensor in the charge pipe after the turbo
bringmyownend
Dec 16, 2010 08:25 PM
Hoe Hopper
Nov 27, 2009 03:17 PM
graftuner34
Apr 15, 2008 05:09 PM
allicedout
Apr 2, 2007 12:28 PM
Emoson
Aug 10, 2004 05:35 PM
