Question on b20 block
Old Jun 18, 2011 | 08:42 AM
vtak2nr's Avatar
Default Question on b20 block
I currently have a b16a gen 2 swap but now i am considering to get a b20 block put in and use my current head + transmission
anyways i called a shop and asked on the b20 id like to put in, i would also like to have it prepped for boost, this way when i am ready later on this yr, the internal work will already been done and i can just slap on a turbo kit
i said 250-300whp he said lower comp pistons and arp studs and it will be enough. is this true or should the block be beefed up more?
Old Jun 21, 2011 | 02:34 AM
Benj@mmin's Avatar
Default Re: Question on b20 block
Stock B20/vtec can handle the some power as long as you have a good tune. You don't need low comp pistons, i'd go higher. Studs and a good HG is enough but if you're gonna want some high power just spend the money and sleeve the block. I have a stock B20/vtec motor with just head studs and a 60-1 at 440hp@12psi.
Old Jun 21, 2011 | 05:57 AM
Golden Eagle's Avatar
Sleeve & final hone 84mm
Copper ''O'' Ring Cylinders
Arias pistons 9.5:1 84mm
Eagle H beam rods
Balance rotating assembly
ARP head studs
ACL race bearings
''Get a good reliable tune''
You can boost from 20 psi up with confidence
Pm us here at G.E. and we will work out a deal for you.
Old Jun 22, 2011 | 06:49 AM
Lee s's Avatar
Good question well answered! ive just got a b20 fitted into my ek9 and was wondering the same.
Leo.
May 20, 2007 12:35 AM
beast59
Nov 9, 2006 03:39 AM
o'malley_808
Oct 29, 2006 01:08 PM
phoenixb16aguy
Aug 16, 2004 09:24 PM
