need to find H22a1 Race bearings
hi guys, im in the process of refreshing my race engine, but now it seems hard to fine ACL race bearing which i used to use them on my outlaw H2B setup, or do i have an alternatives ? ( but not OEM )
i want bearing that can handle high horse power applications, i was using the duraglide bearings for the main and race bearings for the rods
i need help please....
how are acl h22a1 bearings hard to find? im sure someone sells them on HT. to prove that its not hard... ebay.. type.. h22 acl. BOOM!!! there they are!
H22a1 darton sleeved block
manly turbo tuff-1 rods
cp 9.5 comp pistons with upgraded pins
h22a1 stock head
super tech valve springs
typeS cams
golden eagle IM
blox TB
buleyes compR75
front mount manifold
W to A cooler system
evoloution H2B kit
bisimoto twin disck clutch+flywheel
STOCK GSR tranny with cuff
evoloution spool
5.9 dss axe shafts but (( convert to pro level DSS axel+LSD )) not install yet.
26'' slicks.
Best ET was 9.61@226km with stock GSR tranny.
And a big plus is Clevite hasn't filled chapter 11 and restructured, screwing a lot of people and Clevite can actually keep $hit in stock!!!
ACL = smh
If you need coatings, send the bearings out to Swain or any place that does coatings
Have you had any issues with that block yet? Darton sleeves should come with a free rabbit's foot
who's turbo manifold? Custom or someones off-the-shelf one? Setup sounds good though.
no man i dont have any issues with my block , and about the manifold its a custom made because ive searched for something on the shelf and didnt find it , i hope that kaizen speed start to make new products for h2b setups. because i loved the way they work.
hey guys what are you think about king engine bearings ?
i found a set of main coated bearings for race use for h22a1 engine, did anybody use them befor? and could i find a good clearnce results when i use them ?
i asked about them beacuse i didnt hear anybody talk about this brand befor especially in HT so what are you think ?
punkracer
13
Jun 16, 2010 12:36 PM
