hex plug on block behind flywheel
Old Oct 1, 2002 | 10:28 AM
johnzm's Avatar
Default hex plug on block behind flywheel
whats that plug for? its on a b16 sir1. its up and to the left of the rear main. and do any fluids travel behind it?
Old Oct 1, 2002 | 12:29 PM
johnzm's Avatar
Default Re: hex plug on block behind flywheel (johnzm)
ttt
Old Oct 1, 2002 | 01:15 PM
sgT's Avatar
sgT
most likely a plug for the water jacket
Old Oct 1, 2002 | 01:17 PM
tonyxcom's Avatar
Default Re: hex plug on block behind flywheel (sgT)
I believe that is directly inline with the Oil jacket that would feed your squirters if you had them.
Old Oct 1, 2002 | 01:19 PM
sgT's Avatar
sgT
Default Re: hex plug on block behind flywheel (tonyxcom)
there is no oil jacket
the oil jets get oil from a rail at the bottom of the cyls.
Old Oct 1, 2002 | 01:31 PM
earl's Avatar
Isn't there a plug for the main oil galley there?
Old Oct 1, 2002 | 01:36 PM
johnzm's Avatar
Default Re: hex plug on block behind flywheel (earl)
can someone please confirm wether its oil or coolnat behind this plug. i would like to know before i put the trans on if its going to be leaking oil
Old Oct 1, 2002 | 02:15 PM
earl's Avatar
Post a pix so I can tell for sure which plug you are talking about.
Old Oct 1, 2002 | 02:27 PM
sgT's Avatar
sgT
the main oil galley isnt that large though. why would it require such a large plug?
Old Oct 1, 2002 | 02:31 PM
johnzm's Avatar
Old Oct 1, 2002 | 03:44 PM
earl's Avatar
oil
Old Oct 1, 2002 | 04:06 PM
tonyxcom's Avatar
oil
yup. actually taken that off before. You look right down to the oil filter and along that path the oil squirters "t" in.
Old Oct 1, 2002 | 07:57 PM
earl's Avatar
I pull the front and rear plug when hot tanking the block. If the engine went thru some trauma, particles like to hide in that area and come out to haunt you.
Old Dec 9, 2004 | 10:14 PM
xerox445's Avatar
Back from the dead....but, mine hex is leaking badly from a PP bolt coming loose and hitting it. Anyone know if this can be welded back up. Spcefically, what are these plugs made of?
https://honda-tech.com/zero...75499
link 2 thread about this.
B2AutoDesigns
Performance
36
Mar 14, 2012 12:00 PM
NOOdS
13
Nov 28, 2011 02:56 PM
ganjasnack
Aug 14, 2008 07:47 PM
red civic standard
Jun 7, 2004 03:53 PM
