Need help with new system for 08 EX-L Accord
Friend had two 12' Alpine subs and a 1200 watt Alpine amp already mounted and in a box that fits perfectly in my car. I know i can directly hook up the subs and amp to my car. Im also replacing my 2 front speakers with better ones.
Can anyone help me out with what i would need to buy i have no wires at all for it. I would like to not have to put in a new deck in my car and be able to control everything through the controls i have now and just buy converters if possible.
What Alpine amp?
If the amp does not have high level, [speaker] inputs you will need to get a LOC, [line output converter or level output converter].
If you have to get the LOC then you will also need a set of RCAs long enough to reach from the LOC to the amp, you will also need power cable, ground cable, fuse and fuse holder, [ANL type] and some ring terminals, an amp power cable kit, [without RCAs] makes it easy, [you get everything you need] but buy the RCAs separately fot the length you need, [kis will come with 20' RCAs. 94
