b20 vtec knock question
sup ht my b20vtec was knocking but itll only knock when i start it..
when it idles it idles perfect no noise at all. it also knocks when i drive it about 4k rpm. can it be a rod knock?
thanks for the help
thanks for the help
And hope all the clearences are good after you put them in? Now is not the time to try to be cheap. Pull it appart and find out which bearing your shavings came from.
Unless he is running a set of low silicon forged pistons with a large p2w clearence, I highly doubt it would be piston slap. More so though because it wasn't at start up, but rather when he was on the freeway.
Idk personally from my limited knowledge base... a knocking sound around 4k rpms is usually a rod bearing.
iwannarace
10
Jun 13, 2015 06:14 AM
Typeezy
Aug 20, 2008 11:19 PM
