What part is this? And can it be removed?
I replaced the heater hose here I still have a leak from this passage circled in red. It is located right undernear the distributor and goes straight to the firewall. Clearly, mine is in horrible condition and because it's still leaking from here, i want to get it replaced.
What is the part circled in red called?
I am assuming a wrench can take it off where it is circled in green?
It's a 95 Integra LS Auto with the original B18B1 100% stock.
For anyone that is going to comment on the gunk buildup, the coolant did not have a mix of oil in it and I bought the car with 170,000 miles a few months ago so I don't know why the gunk built up and corroded that part. Car runs great aside from this small leak
*edit*
its the part where it says heater inlet hose. i need the actual outlet, not the hose. anyone know the part number and if its removeable?
*edit*
oops. edited.
found out its called a heater outlet or water outlet but i cant find a part number on it anywhere. im assuming it can be removed but im not 100% sure on anything ive said in this post lol
*edit*
actually all the water outlets im finding are for the upper radiator hose
*edit*
Don't know about your year Integra but I believe that's a temp sensor switch.
You getting any check engine light? Getting readings on your temp gauge?
Yes it is replaceable.
no cel and temp is reading fine.
im so confused lol
No home depot would not have it. But that's strange, mines a 97 GSR and I have that same water outlet for my heater. Find a junk head and pull it off?
isnt that the coolant passage for your heater core? if you block it off say good by to heat during the winter time correct me if im wrong?
i JUST found the part number after hours of searching. its called a Tube Joint and the part number is 19500-PE0-000. tomorrow im calling up every honda/acura to see if its in stock and if not then ill order it and just jb weld this one in the mean time or something.
Use a 6-point socket to remove it. You will probably need thread sealant as well for the new one. (My Helm manual is not handy.) There's my $0.02.
Why not just go to your local bone yard, [picknpull] and grab one from just about any Honda/Acura, willing to bet it is the same part on most Honda engines. 94
janos
19
Oct 20, 2021 01:05 PM
