problem with gsr swap
Old Jun 16, 2011 | 06:23 AM
gsrhatchturbo's Avatar
Default problem with gsr swap
first off im a noob to the site, i love it already lots of good threads. with that said i have searched and searched the website for the answer to a question and cannot find it so any help with the answer or a link to the answer will be greatly appreciated.
ok i swapped my 96 gsr motor into my 1992 civic hatch vx. i used the gsr engine wiring harness and left everything else the same, i have everything hooked back up exept two plugs that definetly dont go together but both are leftover so i am at a loss. i have seen alot of post about one plug left over but not two. both cars where running before i swapped the gsr into the hatch i tried turning the car over but got nothing (figured it was worth a try). here are pictures of the two leftover plugs. thanks again
the 6 wire plug is from the car harness and the 3 wire plug is from the engine harness
Old Jun 16, 2011 | 02:11 PM
Default Re: problem with gsr swap
isthis the right section for this?
Old Jun 16, 2011 | 03:31 PM
mouab18c1's Avatar
It's right, but its hard to tell what the sensors are.
Where did the 6 plug harness plug into with the stock motor?
Old Jun 16, 2011 | 06:26 PM
it plugged into the pass side main harness coming off the engine, i believe there are four grouped together. now there is 3 plugs that match on that side but these two obviously dont connect together. thanx
Old Jun 18, 2011 | 12:01 PM
anybody? im at a loss
Old Jun 20, 2011 | 08:10 PM
bump - still havnt had any luck an im up for the night
Old Jun 21, 2011 | 09:39 AM
Builda'Teg_92's Avatar
So both plugs that dont plug in are comming off the main harness? or engine harness? i hope its not your chassis harness cause you could just look in your helems/chilton book, you do have one right?
Well right now im wire tucking a obd1 engine harness and under dash harness so when i go home for lunch ill look to see if i have any of the same plugs.
ok ok 1 main plug 1 engine plug...weired
Old Jun 21, 2011 | 04:52 PM
lillex's Avatar
the 6 wire is for the laf (02 sensor for the vx model). not sure about the 3 wire yet
Old Jun 21, 2011 | 08:45 PM
thanks guy ok i got the six wire plug down pat now i got to figure out the 3 wire plug
bmoney
Aug 13, 2006 01:36 PM
pnltnc
Apr 10, 2004 07:04 PM
ddong2lee
Nov 26, 2003 09:03 PM
