jdm h22 race questions
I have a 96 civic with the jdm h22 motor, LSD tranny, with 15 inch tires. I took it to a 1/8 mile track last night and it spun the tires all the way down the track, I have good tiRes and tried launching at 4 grand, and 5 and both times it happened. Wat can I do to gain more traction?
Well, if you are just spinning all the way down and you don't have wheel hop issues, then tires and weight balance would probably be a good place to start. Get some stickier tires, drop the PSI, get more weight up front if you can, etc.
What is your suspension setup? You might be having too much weight transfer to the rear....
wow!
lol 2nd gear...
4k 5k? way too high on said tires. you need slicks and lots of practice.
otherwise keep practicing control of that fine line.
I'm damn near at an idle when i launch w/ street tires.
still learning my slicks
you have to take into account the track as well, day time, night time, its all gonna change things.
lol 2nd gear...
I've been told 60' and 1/8 mile is all driver, the rest from 1/8 to 1/4 mile and trap speed is the car. So the answer is do whatever it takes to get your 60s down. Slicks make a huge difference.
Starting in second is legit too, if all you do is spin through first, first becomes more like a "granny gear", skip it.
your exactly right. and it was my first time runnin an 1/8 so i guess its gonna take a little practice. maybe launch a 2g on street tires? i think i trapped out at 8.2 spinning the entire track. so i might have high 7s with somewhat of traction. the guy i was running was runnin a b16 vtec so of course i still beat him lol.
I know on slicks all my friends are launching at much higher than that, 7K or better with B-series motors. I was launching my H at 4500-5000 on street tires and getting 15 flat with full interior and subs. That's also in a 92 'lude, so take it FWIW.
I'm one of only a handful of H-series owners here in town [they like their B's and D's around here] and my 'lude is down right now for a turbo build. Once the current motor comes out of that, I'll have and H2B EG build too and I'll have a better idea on launching a Civ with an H in it.
Also, I've never run 1/8s, only 1/4s.
Slicks questions for your setup are more body and upgrade specific. You might want to look around in the Civic forums a bit for help depending on what all you have done to your chassis.
Wow.....nothing changes here. haha!
You need JDM Tires! Mad gripz y0!
Fuzion tires LOL! So you bought a tire/wheel package with no concern for the tires.....FAIL!
