temp gauge?
Old Jun 15, 2011 | 12:13 AM
primered89's Avatar
Default temp gauge?
my temp gauge stopped working when i changed the thermostat and the gasket that goes on the piece that attaches to the upper radiator hose. my question is, what would i have to change or check so i can get it go work again. and its a stock 89 civic sedan. thanx for looking
Old Jun 15, 2011 | 04:03 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: temp gauge?
There is a single wire sensor coming off the side of the head. Look there you probably bumped it or removed it and forgot to put it back on. Either way if it's broke it is a Temperature Sending Unit.
Old Jun 15, 2011 | 09:34 AM
primered89's Avatar
Is it the one that is right under the distributor? if it is, mine shows two wires. the only single that i seen is the one that is on top of the valve cover thats for ground.
Old Jun 15, 2011 | 12:18 PM
Projekt_Ef9's Avatar
The sensor he is referring to is right next to that two wire sensor. It is more torwards the radiator in between the two wire sensor (ECT) and the upper radiator hose.
Old Jun 16, 2011 | 11:32 AM
primered89's Avatar
ok thanx for the info, i just found a loose wire that might be the issu.
DRatedA.W.D.
18
Dec 14, 2011 10:10 AM
k.gren
12
Nov 1, 2011 09:18 AM
HamiltonRex
Oct 6, 2004 01:32 PM
SB97civic
Jan 5, 2004 05:55 PM
KooK
Jun 2, 2003 10:13 PM
