very weird issue with cooling
Old Jun 14, 2011 | 05:38 PM
sh!ft's Avatar
Who the fack changed my title?!
Default very weird issue with cooling
ok, so, 92 civic 4 door. auto. b15b7. replaced the following: thermostat, flushed the complete cooling system, fixed the faulty fan issue, confirmed the water pump was NOT leaking, and still made a strong current. no faulty wiring at all.
why when i am driving, i notice when i get up to 60/70mph, the temp rises really high, but cools down when i coast for a sec and get back on the gas it cools down. what the heck would cause this? im thinking the head is trashed.
Old Jun 14, 2011 | 05:51 PM
fcm's Avatar
fcm
Old Fart
Default Re: very weird issue with cooling
Did you bleed the system properly?94
Old Jun 14, 2011 | 06:01 PM
sh!ft's Avatar
yes i burped it and everything, ive not burped the system before and never had a problem like this before.
Old Jun 14, 2011 | 11:47 PM
civickiller's Avatar
I say radiator
Old Jun 15, 2011 | 05:32 AM
fcm's Avatar
fcm
Old Fart
Which is correct?
1-Temp. goes up, [over heats] one time and then back to normal?
2-Temp. goes up every time your speed goes up?
3-Temp. only goes up, [over heats] from cold engine? 94
Old Jun 15, 2011 | 09:03 AM
sh!ft's Avatar
Originally Posted by fcm
Which is correct?
mainly option 2. and itll stay up until i turn on the heater, then it will go back down to normal. when i hit 60/65, it will go back up, then i let off the gas, cruise back down to 50/55 then get back on the gas, and then it cools down.
when i turn the car on in the morning, it takes less than 30 secs to warm up. unlike my other cars which would take like AT LEAST 5 min to warm up.
Old Jun 15, 2011 | 11:05 AM
fcm's Avatar
fcm
Old Fart
Remove the rad cap, start engine, look for air bubbles, it sure sounds like a HG leak
Have you checked oil for coolant or done a HC, [hydrocarbon] test in coolant? 94
Old Jun 15, 2011 | 11:26 AM
sh!ft's Avatar
well, when i flushed the system, i waited for the thermo to open, then i put a water hose in the bottom rad hose and turned it on, water came out of the top hose, it had smallllll bubbles, almost like steaming water does when spaghetti is cooking, thats about it. like the white foamy bubbles, nothing more than that and only in small increments.
Old Jun 15, 2011 | 12:11 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Agreed, if it's related to speed then it sounds like HG.
Old Jun 15, 2011 | 12:27 PM
sh!ft's Avatar
FACK O_O!
Old Jun 15, 2011 | 12:58 PM
v.i.gsr's Avatar
check polarity of the fan, make sure its pulling and not pushing..
Old Jun 15, 2011 | 01:54 PM
sh!ft's Avatar
it is pulling correctly
Old Jun 15, 2011 | 04:08 PM
Mattb16teg's Avatar
Community Builder
Compression and leak down test!
Or like fcm suggested, take off rad cap and start car. If the HG is blown badly it will shoot coolant out of the rad neck.
Old Jun 16, 2011 | 09:38 AM
sh!ft's Avatar
ok so it ended up being the head, there were rough spots on the exhaust side between 2 and 3 and 1 and 2, will post pix later for reference.
Old Jun 16, 2011 | 10:12 AM
Mattb16teg's Avatar
Community Builder
Did you just straight edge it and find out?
Old Jun 16, 2011 | 01:21 PM
sh!ft's Avatar
nope took it to the hop, 50 bucks later and if i can remember correctly, .19 or 20 off its ready to go!
Old Jun 18, 2011 | 09:36 AM
sh!ft's Avatar
FACK!
still over heating! the only thing i have yet to replace is the radiator! might end up doing that. and if it still aint cooling down, time for a new motor. any one think it could be a hair line crack?
Old Jun 18, 2011 | 12:37 PM
.all-motor+.eG8's Avatar
pull out your spark plug wires and see if oil comes out. i had the same problem.. it was too much oil around my spark plugs. go figure
Old Jun 18, 2011 | 12:38 PM
sh!ft's Avatar
that would not be the issue since this car is not equipped with an oem oil cooler.
Old Jun 18, 2011 | 04:53 PM
sh!ft's Avatar
new water pump just added, still nothing. the rad cap is good, disconnected the heater core and tried to see if that worked, still over heating. flushed the **** too. had the head milled, new iacv, new pcv system(hoses n valve), im really starting to think its the block, the rad looses a very slight ammount of coolant after like 30 min of driving. which also leads me to believe its a fuxed block.
Old Jun 19, 2011 | 12:02 PM
sh!ft's Avatar
O_ !#(%*&!$)(%&$%)(!$@#_(%&!@#_)&*HEWOI#$!M)!~~~~~~~~ ~~!!!!!!!!!!!!!!!!!!!!!!!
im seriously gonna hurt some one. it ended up being the facking 1 wire temp sensor under the dizzy!
Old Jun 21, 2011 | 04:03 PM
dntnedvtec's Avatar
Glad you found the problem. WELL, at least you PM'ed(Preventative maintenance) your car.
m3touk_85
13
Dec 14, 2011 06:57 AM
tech410
15
Sep 22, 2010 05:22 AM
EM88
Jul 21, 2009 03:12 AM
moosta936
Jul 9, 2007 05:59 PM
CptCorN
28
Feb 6, 2005 06:23 PM
